RCU Forums - View Single Post - DX6i Binding issues
Old 06-29-2010 | 03:52 PM
pdm52956
Default RE: DX6i Binding issues
ORIGINAL: Boogity08
thanks for the reply's; I have attempted to re-bind various ways, which the lights on the rx blink fast and appears to bind, the lights then go solid. However no juice or controls are going to servos at all..... I have also tried standing away from the rx 10 feet or so with the same problem. </p>
One other question; if the receiver is unplugged from the battery does this lose the bind?</p>
Boy, someone says Spektrum and everyone goes straight for the "how to bind" without answering any questions.
You say that you have the rx bound to the tx and due to the solid light, I would say you're correct. I'm wondering, are you sure that you have the servo wires plugged in correctly and not reversed? In other words, if the servo wires plug into the top of the rx, are the black leads of the wires towards the outside of the rx or towards the inside? Be sure that the black wire is towards the outside of the rx. If it is, I would at least consider changing out the rx if you have a spare to see what, if any difference that makes. It is possible that the rx is bad.
One to the battery disconnect............no, disconnecting the battery should not cause the rx to loose bind.
I apologize to anyone that took offense to my first comment.
Hope that helps.
