RE: UFO 25 - Planning
I have received a few PM's and emails lately about this project so I thought an update would be in order. I'm in the throws of finishing things up and should have something more concrete in the following couple of weeks. I'd like to take the opportunity to thank Bryan for his help with the rib profiles on both the wing and stab as I went through a few different iterations of layouts until I was satisfied with the reduced scale re-design.
I plan to get a first kit cut to evaluate it's un-built weight and consider whether it might be possible to shed a few ounces by changing some of the sheet stock. The fuse sides and top are the two primary thicknesses that I'm considering revising once I receive the first cut.
David.
