RE: Radio controlled servo?
This sounds exactly like what I'm looking for thank you so much if you could go into more detail I would reallyappreciateit! Thanks again! Lets say I have everything setup this way to control the motor, now the motor will be used a couple of times a day max for just a couple of seconds, but I need thereceiveron the motor to be on all day every day so that I can communicate with it through out the day when I need to. Doing it this way what kind of battery life should Iexpectout of it & how should I set it up to get the best battery life. Should I have aseparatebattery for thereceiverand the motor?
