Weird problem
OK, got a problem i just cant quite figure out. When I go to start the motor the pull start won't retract in. I took the pull start off and it pulls and retracts fine off the engine. I can get the pull start to retract if I turn the flywheel clockwise. So I figured something was binding or sticking in the motor. I pulled the entire motor apart, cleaned, oiled and put everything back together and it still does the same thing.
This is an Axial .28 bout 3 years old
Any thoughts?
