RCU Forums - View Single Post - Need help charging
Old 07-04-2010 | 06:45 PM
guver
My Feedback: (325)
Default RE: Need help charging
Uh, yep. 750 ma and 12 volts is about 9 watts. That will be your limit to charging.
Since your battery is a 3S (about 12 volts) then you should limit current to 700-800 ma.
The charger you have is 50 watts max, and sooner or later you might max it out so look for a ps around 50+ watts.
