Webra speed 70f
I recently became the owner of this webra that I know little about. It does have a dynamix carb, and I have a pretty good instruction sheet on how to set the mixture.
Does anyone here own one of these engines? I see the engine is rated for speeds up to 17.5K? Is this engine really timed to run at these speeds? Or should I run this in the rpm range of a sport .61 with a sport muffler?
These specs are copied off the webra site.
volum ccm / cu in 11.50 / 0.70
power PS / KW 2.50 / 1.85
rpm 1/min 2500 - 17500
bore mm 24.70
stroke mm 24.00
weight g 470
system of control front intake
porting Schnürle
ballbearing 2
liner piston set ABC
crankshaft mm 9,5
crankshaft 1/4" 28UNF
carburettor 1024/316
