Webra speed 70f
My Feedback: (264)
I recently became the owner of this webra that I know little about. It does have a dynamix carb, and I have a pretty good instruction sheet on how to set the mixture.
Does anyone here own one of these engines? I see the engine is rated for speeds up to 17.5K? Is this engine really timed to run at these speeds? Or should I run this in the rpm range of a sport .61 with a sport muffler?
These specs are copied off the webra site.
volum ccm / cu in 11.50 / 0.70
power PS / KW 2.50 / 1.85
rpm 1/min 2500 - 17500
bore mm 24.70
stroke mm 24.00
weight g 470
system of control front intake
porting Schnürle
ballbearing 2
liner piston set ABC
crankshaft mm 9,5
crankshaft 1/4" 28UNF
carburettor 1024/316
The Webra "Speed" series are fine, powerful engines. They like to rev and like small props. If the specs say 17.5k, I don't doubt it at all. I have a Speed .32 that turns a 10-4 APC at 15.3k. The Dynamix carb can by picky to adjust, but it's what helps give the engine its power. The C (chrome) part of the ABC is extremely hard and the engine definitely needs break in time. Don't run it slobbering rich during this, but in a only SLIGHTLY lean two cycle. These engines are carefully built with tight tolerances and will last you a long time if properly taken care of. Use a castor/synthetic oil blend fuel like Morgan's Omega. The Speed engines like nitro, too, so even up to 25% is ok although they run just fine on 10%-15%.
ORIGINAL: rcdude7
This webra is not a Typical ''ABC''. The cylinder is chromed brass and the piston has a dykes ring on it.
My Feedback: (29)
The Speed 70 is a rare and desirable engine. It is mechanically stronger and better balanced than the speed 80, which is just a bored 61LS. Prop it the same as a 60 (13000 rpm) and enjoy better power and fuel draw. An ABC-ring setup lets the engine handle a lot of heat while being able to eat dirt with minimal damage. It can use the same muffler/header as OS61fsr and Enya 60X.
My Feedback: (264)
Thanks all for the advice, I bought the speed 70 because I already have a speed 50 and 91, they are great running engines. I had never seen or heard of the 70, but bought it based on the speed engines reputation of being great running engines.
This is the only 70 I have come accross, why are they not more common?
