RCU Forums - View Single Post - Servo Chatter help
Old 07-06-2010 | 10:41 AM
Rodney
Default RE: Servo Chatter help
The first thing to check is the connections. If you are using any extensions, their connections are often problems. The second is to make sure you have adequate size leads, especially on the power leads (the signal lead carries very little current and can be a smaller gage) and make sure the battery is adequate. Any high impedance in the battery, battery leads or switch can cause this.
