Electric General Discussion General Discussion forum about rc electric related aircraft, accessories, flight, tips, etc.
Servo Chatter help
Old 07-05-2010 | 11:44 PM
Leisure_Shoot's Avatar
Default Servo Chatter help
Can someone help me with a noisy servo issue?
Wanting better range (and just generally never leaving well enough alone, and wanting to add ailerons next), I've replaced my HZ Super Cub receiver with a 2.4GHz receiver to use with my Spektrum DX6i.
Everything seems to be working fine, but the servo's, or one of them at least seems to be fluttering.
It seems like it might improve when I put my fingers on the stick, but I'm not certsure of that.
I am using :
stock HZ 11.1V 1300mAh LiPo
stock 480 motor
electrifly C-12 Micro ESC
Spectrum AR6110 receiver
E-flite S75 sub-micro servo's
Am I using a wrong component?
How do the voltages work?
Does the receiver or ESC adjust the voltage from the battery to the receiver, andultimately the servos?
One strange thing is that the servos didn't make noise when sitting on the counter, when I pre-wired and tested the components.
I mounted them to a styrene plate, side by side. Is there such a thing as interference between closely (side by side, touching) mounted servos?
Thanks for any assistance.
Old 07-06-2010 | 10:41 AM
Default RE: Servo Chatter help
The first thing to check is the connections. If you are using any extensions, their connections are often problems. The second is to make sure you have adequate size leads, especially on the power leads (the signal lead carries very little current and can be a smaller gage) and make sure the battery is adequate. Any high impedance in the battery, battery leads or switch can cause this.
Old 07-06-2010 | 01:01 PM
Sometimes, you can get chatter if you are just holding your TX too close to the plane. Rich
Old 07-06-2010 | 11:13 PM
ORIGINAL: richg99
I tried walking into another room and it didn't stop.
Old 07-06-2010 | 11:50 PM
ORIGINAL: Rodney
The servos plug directly to the receiver.
No issues with connections - larger gauge wire and good connectors (Dean"s)
I'll revisit the soldered connections and verify everything is looking good.
Can I test impedence from the ESC motoer wire to the motor lead where it enter the motor, with an ohm meter?
What measurement would I be looking for?
