RE: TT Pro 46 - work with 60 size trainers?
I have a NIB SIG <span class="J-JK9eJ-PJVNOc">Kadet</span> Senior and the recommended engines are .29-.40 CU. IN. Glow or .35-45 CU. IN. 4-Stroke. So it looks like your .46 would work in the SIG <span class="J-JK9eJ-PJVNOc">Kadet</span> Senior. I'm sure that youcould find a 60 size trainerthat the manufacturer recommends an engine that is larger than yours. If you want to use your .46 engine you will just need to look for a 60 size that your engine falls in the recommended sizerange. Good luck in your search. I hope it works out for you the way you want it to.
<span class="J-JK9eJ-PJVNOc">rwf</span>
