RCU Forums - View Single Post - YS110s Mid Range RICH
Old 07-08-2010 | 09:36 AM
petec's Avatar
petec
My Feedback: (58)
Default RE: YS110s Mid Range RICH
ORIGINAL: frenchie79
High 1 1/8 out
Low-3 1/2 out
Regulator 1/2 turn out from bottom (most of my others are flush)
The low speed and regulator setings do not sound right....As if the regulator is not closing fully or the spring is weak. When you say 1/2 turn from bottom I take it to mean that you screwed the regulator fully shut. If that is the case you may have over compressed the spring which would give you these symptoms.
