Am I Missing Something Here!
I got a few emails wanting to know part numbers I order from McMaster Carr, so here goes:
98335A034 Zinc-Plated Steel Hairpin, Fits 3/16"-1/4" Shaft Dia Range, 15/16" Overall L 1 Pack
1 Pack shipped 07/23/2003 via UPS GROUND on Shipment-1. 1 Box shipped.
2 91251A148 Alloy Steel Socket Head Cap Screw, 6-32 Thread, 1/2" Length 1 Pack
1 Pack shipped on Shipment-1 (See above)
3 91083A007 Plain Steel Sae Flat Washer, #6 Sz, 5/32"ID, 3/8"OD, .036" Thk, Approx 790/PK 1 Pack
4 90633A007 GR2 Znc Plt Stl Hex Thin Nylon-Insert Locknut, 6-32 Screw Size, 5/16" Width, 1/8" Height 1 Pack
5 90975A007 Steel Tee Nut, Zinc-Plated, 6-32 Internal Thrd, 1/4" Barrel Ht 1 Pack
71245K35 Stranded Single-Conductor Machine Tool Wire, 14 Awg, .136" Od, 600 Vac, Green 10 Ft.
10 Ft. shipped 07/09/2003 via UPS GROUND on Shipment-1. 1 box received 07/14/2003 at 11:24:00 AM by N BOOTH at RECEIVER.
2 71245K32 Stranded Single-Conductor Machine Tool Wire, 14 Awg, .136" Od, 600 Vac, White 10 Ft.
10 Ft. shipped on Shipment-1 (See above)
3 91458A130 Loctite 222 Threadlocker ADHESIV,.5 Ml,purple 2 Each
2 Each shipped on Shipment-1 (See above)
4 92196A110 18-8 Stainless Steel Socket Head Cap Screw, 4-40 Thread, 1/2" Length 1 Pack
5 92196A115 18-8 Stainless Steel Socket Head Cap Screw, 4-40 Thread, 1" Length 1 Pack
6 92196A302 18-8 Stainless Steel Socket Head Cap Screw, 4-40 Thread, 1-1/4" Length 1 Pack
7 91831A005 18-8 Stainless Steel Hex Nylon-Insert Locknut, 4-40 Screw Size, 1/4" Width, 9/64" Height 1 Pack
8 90975A002 Steel Tee Nut, Zinc-Plated, 4-40 Internal Thrd, 1/8" Barrel Ht 1 Pack
9 90945A707 18-8 Stainless Steel Nas 620 Flat Washer, 3L Sz, No. C3L, .102"ID, .180"OD, .014" Min Thk 1 Pack
10 98335A024 Zinc-Plated Steel Hairpin, Fits 1/8" Shaft Dia Range, 19/32" Overall Length 1 Pack
51605K13 Mini Acetal Snap-Lock Tube Coupling, Socket W/Barb, Straight Through, 1/16" Tube Id 10 Each
6 Each shipped 07/07/2003 via UPS GROUND on Shipment-1. 1 box received 07/09/2003 at 9:55:00 AM by N BOOTH at RECEIVER.
4 Each shipped 07/07/2003 via UPS GROUND on Shipment-2. 1 box received 07/10/2003 at 10:07:00 AM by T BOOTH at RECEIVER.
2 5070A11 Quick-Grip Squeeze Clamp, 1-1/2" Maximum Opening 2 Each
2 Each shipped on Shipment-2 (See above)
3 5070A12 Quick-Grip Squeeze Clamp, 2" Maximum Opening 2 Each
51605K11 Mini Acetal Snap-Lock Tube Coupling, Plug W/Barb, Straight Through, 1/16" Tube Id 10 Each
10 Each shipped 06/30/2003 via VELOCITY-HOU on Shipment-1.
Line Part Number Description Quantity
1 74695A71 Duo-Pak Dispensing Cartridge Gun And Mixer, Dispensing Gun With 1:1 & 2:1 Plungers 1 Each
1 Each shipped 06/30/2003 via VELOCITY-HOU on Shipment-2.
2 51135K131 Silicone Rubber Tubing, Firm, 3/32" Id, 7/32" Od, 1/16" Wall, Blue 10 Ft.
10 Ft. shipped 06/30/2003 via UPS GROUND on Shipment-1. 1 box received 07/03/2003 at 9:46:00 AM by N BOOTH at RECEIVER.
3 5236K62 Silicone Rubber Tubing, Firm, 3/32" Id, 7/32" Od, 1/16" Wall, Red 10 Ft.
10 Ft. shipped on Shipment-2 (See above)
4 50335K34 Multiline Ether-Based Polyurethane Tubing, 1/16"ID,1/8"OD, Green-Yellow-Orange-Red, Four-Line 12 Ft.
12 Ft. shipped on Shipment-2 (See above)
5 74695A27 Plastic Hand Plunger For, Duo-Pak Dispensing Cartridge Gun And Mixer 1 Each
1 Each shipped on Shipment-2 (See above)
6 74695A12 Bayonet Mixer Nozzle 5.9"L,1/16"TAPER Tip For, Duo-Pak Dispensing Cartridge Gun And Mixer 12 Each
12 Each shipped on Shipment-2 (See above)
7 74695A57 Duo-Pak Dispensing Cartridge Gun And Mixer, Bayonet Mixer Nozzle, 3.4" Long, 1/16" Taper Tip 12 Each
AEROPOXY IS Hysol 9462 1813a227 THEY CALL IT 9642 BUT THE NUMBERS ARE JUST TRANSPOSED AND I'M NOT GOING TO FIGHT THE SYSTEM TO HAVE IT CHANGED. BUT IT IS VERIFIED THAT THE HYSOL THEY SELL UNDER PART # 1813A227 IS THE EXACT SAME AS BVM AEROPOXY.
