RE: can vs spray primer
Rattle cans are convenient and certainly have their place. However one of the drawbacks is the amount of solids that can be put through the aerosol tip which is usually around 15-17% which means it takes a good number of coats to get any kind of build. Using a spray gun you can get more build in less coats because the coating is generally not thinned as much for the application.
