RCU Forums - View Single Post - Jr 8911 servo. Help.
Old 07-10-2010 | 10:37 AM
booker-RCU
My Feedback: (43)
Default RE: Jr 8911 servo. Help.
ORIGINAL: c_makhija
Hi Dave,
I normally use the 12X but tried these servos out with the 11X i just bought. A123 battery unregulated directly into a SPCM 10 ch synthesized Rx. May be the servo did not like the slightly higher voltage. I just used this setup for testing the servo,final setup will be regulated voltage via a powerbox champion RRS. Ran the 8911 for 10 min more, regulated this time and seems to be running fine. Slightly confused now.
Chaitanya.<br type=''_moz'' />
I may be missing something here but you said you used a SPCM 10 ch synthesized Rx and a JR 11X transmitter. The 11X is 2.4 mHz and the receiver is 72 mHz. How did you get them to work together?
