RCU Forums - View Single Post - DLE30 rear induction conversion!
Old 07-11-2010 | 08:18 PM
  #661
captinjohn
Default RE: DLE30 rear induction conversion!
ORIGINAL: richiepingi3
Hi, has anyone used the new rear carb conversion for the DLE30? how does it work? Can the carb be turned either way and still work properly?
<hr />Just remove the 2 bolts holding carb &amp; everything on to engine. If you see 2 pulse holes accrost from each other....it is indeed revesrable...and your 1/2 done!
<hr />Now while we are talking about the rear induction DLE30cc engine, I think I am going to make a ring out of 1/8 .125 thick aluminum plate and make a brace like the one below...that is now a thin white piece ofcardboard. You could also drill &amp; tap this round plate to hold other things...like a choke rod support! What do you think? Capt,n
