RCU Forums - View Single Post - Can't get HobbyKing 40A ESC to calibrate?
Old 07-14-2010 | 09:23 PM
nickrummy's Avatar
nickrummy
Default Can't get HobbyKing 40A ESC to calibrate?
This is the ESC I have
http://hobbycity.com/hobbyking/store...dProduct=11430
I'm using a 3PK with FASST System. I have servo power but for some reason I can not get the motor to calibrate no matter what I try. I am getting power and it does calibrate, just incorrectly.
The manual says to turn the TX on and hold the trigger in maximum position. So I do that, then plug the ESC in and It'll make a chime noise. It's supposed to make 2 beeps then I'm supposed to go to minimum position. After the chime I get I go to neutral and nothing happens. It just sits there. So I'll move the trigger to a position (I've tried about every position) and then I'll get another set of chimes. Then it gets crazy. The thing will will rev real high and it might be reversed. It's puzzling. I had it once to where I could ALMOST turn the throttle trim all the way up and it stopped the motor at neutral but I knew that was wrong......
Any ideas?
