RE: big stick 40 arf
A few people have noted that the GP Stik tends to be nose heavy. The manual says the engine should be mounted so the thrust washer is 4-3/4" [120mm] from the firewall. If you move the engine back slightly (leave enough room to route the fuel lines) it will help combat the nose heavy condition.
