RCU Forums - View Single Post - CA Hardening of Balsa Wood
Old 07-15-2010 | 04:16 PM
G.Barber's Avatar
G.Barber
Default RE: CA Hardening of Balsa Wood
It also depends on the type of plane you are building.
If you're building a trainer, the manual should spell out every little step. If you're building an Aeroworks P-51, the manufacturer should be able to assume that if you're building their advanced product, you should have all building/ assembling skills down already.
Yes, there is a fine line between over-writing a manual and assuming the buyer posses the knowlege to put their plane together, but it will vary by what you're building.
