RCU Forums - View Single Post - CA Hardening of Balsa Wood
Old 07-16-2010 | 09:16 PM
freakingfast
Default RE: CA Hardening of Balsa Wood
ORIGINAL: nonstoprc
To remove screws that have been epoxy or CA glued to the mounting holes, apply some heat through the soldering iron tip to the head of the screw. In couple of minutes the glue will loose the grip.
Very good tip!
