RE: Eclipse 7 /Spectra 72 pin connection issues
I have the promotional module on an Eclipse 7 and have flow it with no problems. Ithought the module beeping meant the voltage downlinked from the RX was low? Are the LEDS on the back of the module flashing or solid when you get the problem.
Maybe Iam misunderstanding how the promotional module works.
Good luck and hope you find something solid to fix there.
Jim D.
