RCU Forums - View Single Post - Expanded Use of Ignition Battery Question
Old 07-20-2010 | 06:26 AM
Howard
My Feedback: (55)
Default Expanded Use of Ignition Battery Question
I am assembling an Aeroworks Cessna 195 that comes with a set of running lights and it will be powered by a DLE 30. I was thinking of simplifying things by using an A123 2S1P 2300 mah battery (in series with a IN4007 silicon diode) to power both the ignition and the lights. The lights would be turned on/off by a separate Rcexl remote switch. My concern is whether the switch end of the remote switch will prevent any ignition noise from being radiated through the lighting wire harness or does the remote switch only prevent ignition noise from reaching to the receiver connection? I think I said that correctly
Howard
