RCU Forums - View Single Post - Corona and 9c setting ?
Old 07-28-2003 | 02:47 AM
charleyh
Default Corona and 9c setting ?
I have a 9CH and not sure about the plane version but should be the same.
Any way. I have my D/R set at about 50-60% and the exp at -40%, but it boils down to what feels good to you and is comfortable. I like it soft around the center of the stick so I don't over compensate.
As far as turning them on and off you should be able to assign them to whatever switch you want. At the bottom of the D/R EXP screen there is a SW with a letter beside it. That is the switch it is assigned to but you can change it.
I have all mine assigned to switch A down is on up is off.
It should be pretty well explained in the manual but if you have any more questions let me know.
See ya,
