Corona and 9c setting ?
You should also be able to select "null" at some point on the screen, but I would have to go look at mine to be sure.
You can also set it to a particular switch, and then set both switch positions to the same value, like switch up is 100% and switch down is 100%. Then it wouldn't really matter if you hit the switch..
