ORIGINAL: rorrock
EPF have a new allow 64mm unit out that puts out 1.12kg on 4s
That why these great little fans that put out 1.2kg on 4s at 57A will be available there as well.
Rob
Wow she gets more powerful every day
Its great if you can get the aero bodies to accept metal blades, I wish you good luck with it, but it doesnt address the issue of efficiency, and 57 amps to get the same thrust as the current 64mm fans get at41 amps brings us back to the same problem of battery size and/or stress induced on the batteries.
