Sig Somethin' Extra
I use 1/2" drywall on top of my flat building table. It comes in 4'X8' sheets, it's flat, is easy to cut to size, pins stick in it easily, you can cut wood or covering on it with razer blades, you can write or draw patterns on it, it's only about $5.00 per sheet and when one side gets ragged you can turn it over and use the other side.
