RCU Forums - View Single Post - Carb Linkage On Wrong Side?
Old 07-22-2010 | 02:11 PM
krashkart
Default Carb Linkage On Wrong Side?
Not there yet and have not had to address the problem but it appears that my model set the servo up on one side of the tray for the throttle and the ARF is designed to have the linkage exit on the left side as you are looking at the firewall.
But the linkage on my Saito 82 is on the right side of the motor as I look at the firewall where it will be mounted in the future.
Does the linkage reverse on the motor or do you move thelinkage from the servoto the other side?
Or is there another solution?
