RCU Forums - View Single Post - Programming Flaps and Ailerons~DX6i
Old 07-22-2010 | 06:21 PM
Adui
Default RE: Programming Flaps and Ailerons~DX6i
Greetings,
I have the same radio. I programed Flaperons and use them in the manner you described. However, if I understand correctly you will have to use a single port for Ailerons and the aux port for flaps if you want to have both flaps and ailerons. Use a y harness for each if you use two servos for the rons and you will be fine. Just dont forget to add up elevator mix to the flaps or you could get a surprise!!
Bottom line, you cant to my knowledge have both a separate flap and aileron set up and not use a y for the ailerons and flaps if you use two servos for the ailerons..
