RE: Carb Linkage On Wrong Side?
Another nice thing about using the "hairpin turn" as Ken suggested is that you can also use the same technique to keep the push rod from the servo outside the fuel tank area and when you make that hairpin turn bring it back closer to the cylinder (makes it easier to route the pushrod around the tank without creating undue friction).
