RE: nitro or brushless.
It amazes me how people who have owned both can say that nitro is "less maintenance" It requires an extensive break-in, then constant fiddling with the carb to get it to run right depending on the weather. With electric, you plug in a battery and away you go. Aside from occasionally spraying the crud out of the motor, there is no maintenance or setup involved. Nitro has it's perks, but it isn't easier by any standard.
