RCU Forums - View Single Post - Bolt on wing for an LT40
Old 07-25-2010 | 08:41 PM
w8ye's Avatar
w8ye
My Feedback: (16)
Default RE: Bolt on wing for an LT40
I find it difficult to post right now as the images are not loading. I got so excited, I made a post in the old LT-40 thread
I have an older LT40 ARF from back in the 90's
About 4 yrs ago I decided to make it a Tail dragger with bolt on wings
I removed the covering under the wing for the part that fits over the fuselage.
I made a plywood wedge for the front half of the wing with two 1/4" dowels protruding.
In the front bulkhead, F-2 I drilled to matching 1/4" holes for the two dowels
At the rear, I covered the bottom of the wing with a piece of 1/8" ply with hardwood shims to allow for the dihedral
There's already a plate in the rear that I added 1/4" ply under
I drilled down through the plywood doubler on top of the wing clearance holes for 1/4" wing bolts
The plywood in the fuselage was tapped 1/4-20 for the nylon wing bolts. I put thin CA in the hole and when dry re-tapped the hole
While I was at it I used the rear reinforcement to raise the trailing edge of the wing 1/4" to subdue the tendency of the plane to climb with increased power
<div style="overflow: hidden; color: rgb(0, 0, 0); background-color: transparent; text-align: left; text-decoration: none; border: medium none;">
</div>Here is my LT-40
these next two images are not my plane but my plane looks like this when you take the wing off
[img]{akamaiimageforum}/upfiles/106349/Gb90684.jpg[/img]
[img]{akamaiimageforum}/upfiles/106349/Ig13571.jpg[/img]
