RE: Large Clear CANOPY Glue Method
i always apply masking tape to the entire canopy first, then insert it into the frame and use a pencil to draw an outline of the frame, then carefully remove the tape in the area to be glued, then you won't scratch the canopy while gluing it in. you can also use the glue of your choice as it can't get all over the canopy because it's masked with the tape. i use V-poxy.
