here ya go dude.......
tm: Library Version 4.2, Copyright (C) 1999-2005, IPACS
tm:
http://www.ipacs.de
tmsystem: init random with 706512154
tmsystem: cpu type=(nlogical=1) (nphysical=4) (no hyper-threading)
tmsystem: cpu=3825 Mhz
tmsystem: memory=(physical=4094MB, avail=2592MB) (virtual=2047MB, avail=1831MB)
tmsystem: operating system=Version 6.1 (Build 7600)
tmgl: loading font v2 texture/arial10.tmf=(256x256) (32x255) ok
tmgl: loading mouse texture/mouse.tmt=ok
tmprogram: AeroFly Professional Deluxe Version 1.9.1.3, Copyright © 1998-2005 IPACS
loading configfile config/main.mcf=ok
loading player configfile config/player1.mcf=ok
loading player configfile config/player2.mcf=ok
directsound: register sound sound/beep.wav=ok
directsound: register sound sound/balloon.wav=ok
directsound: register sound sound/crash.wav=ok
directsound: register sound sound/splash.wav=ok
directsound: register sound sound/glider.wav=ok
directsound: register sound sound/glider2.wav=ok
afdesign: init ok
tmgl: loading font v2 texture/menufont.tmf=(512x512) (32x255) ok
directinput: init=ok
tmsystem: current monitor frequency=60
init window=(window=800x600) (screen=1680x1050) (32bpp) (60Hz) (window)
directsound: init=(speakerconfig=unknown) (cont.rate) (primary 16bit) (samplerates 100,200000) (1 hwbuffers) (0 hwbytes)
init pixelformat=ok
gl: vendor=ATI Technologies Inc., renderer=ATI Radeon HD 4800 Series , version=3.3.10061 Compatibility Profile Context
gl: (viewport=8192x8192) (texturesize=8192) (stencil=8)
gl: extensions=GL_AMDX_debug_output GL_AMDX_vertex_shader_tessellator GL_AMD_conservative_depth GL_AMD_debug_output GL_AMD_draw_buffers_blend GL_AMD_name_gen_delete GL_AMD_performance_monitor GL_AMD_sample_positions GL_AMD_seamless_cubemap_per_texture GL_AMD_shader_stencil_export GL_AMD_texture_cube_map_array GL_AMD_texture_texture4 GL_AMD_vertex_shader_tessellator GL_ARB_blend_func_extended GL_ARB_color_buffer_float GL_ARB_copy_buffer GL_ARB_depth_buffer_float GL_ARB_depth_clamp GL_ARB_depth_texture GL_ARB_draw_buffers GL_ARB_draw_buffers_blend GL_ARB_draw_elements_base_vertex GL_ARB_draw_instanced GL_ARB_explicit_attrib_location GL_ARB_fragment_coord_conventions GL_ARB_fragment_program GL_ARB_fragment_program_shadow GL_ARB_fragment_shader GL_ARB_framebuffer_object GL_ARB_framebuffer_sRGB GL_ARB_geometry_shader4 GL_ARB_half_float_pixel GL_ARB_half_float_vertex GL_ARB_imaging GL_ARB_instanced_arrays GL_ARB_map_buffer_range GL_ARB_multisample GL_ARB_multitexture GL_ARB_occlusion_query GL_ARB_occlusion_query2 GL_ARB_pixel_buffer_object GL_ARB_point_parameters GL_ARB_point_sprite GL_ARB_provoking_vertex GL_ARB_sample_shading GL_ARB_sampler_objects GL_ARB_seamless_cube_map GL_ARB_shader_bit_encoding GL_ARB_shader_objects GL_ARB_shader_texture_lod GL_ARB_shading_language_100 GL_ARB_shadow GL_ARB_shadow_ambient GL_ARB_sync GL_ARB_texture_border_clamp GL_ARB_texture_buffer_object GL_ARB_texture_compression GL_ARB_texture_compression_rgtc GL_ARB_texture_cube_map GL_ARB_texture_cube_map_array GL_ARB_texture_env_add GL_ARB_texture_env_combine GL_ARB_texture_env_crossbar GL_ARB_texture_env_dot3 GL_ARB_texture_float GL_ARB_texture_gather GL_ARB_texture_mirrored_repeat GL_ARB_texture_multisample GL_ARB_texture_non_power_of_two GL_ARB_texture_query_lod GL_ARB_texture_rectangle GL_ARB_texture_rg GL_ARB_texture_rgb10_a2ui GL_ARB_texture_snorm GL_ARB_timer_query GL_ARB_transform_feedback2 GL_ARB_transform_feedback3 GL_ARB_transpose_matrix GL_ARB_uniform_buffer_object GL_ARB_vertex_array_bgra GL_ARB_vertex_array_object GL_ARB_vertex_buffer_object GL_ARB_vertex_program GL_ARB_vertex_shader GL_ARB_vertex_type_2_10_10_10_rev GL_ARB_window_pos GL_ATI_draw_buffers GL_ATI_envmap_bumpmap GL_ATI_fragment_shader GL_ATI_meminfo GL_ATI_separate_stencil GL_ATI_texture_compression_3dc GL_ATI_texture_env_combine3 GL_ATI_texture_float GL_ATI_texture_mirror_once GL_EXT_abgr GL_EXT_bgra GL_EXT_bindable_uniform GL_EXT_blend_color GL_EXT_blend_equation_separate GL_EXT_blend_func_separate GL_EXT_blend_minmax GL_EXT_blend_subtract GL_EXT_compiled_vertex_array GL_EXT_copy_buffer GL_EXT_copy_texture GL_EXT_direct_state_access GL_EXT_draw_buffers2 GL_EXT_draw_instanced GL_EXT_draw_range_elements GL_EXT_fog_coord GL_EXT_framebuffer_blit GL_EXT_framebuffer_multisample GL_EXT_framebuffer_object GL_EXT_framebuffer_sRGB GL_EXT_geometry_shader4 GL_EXT_gpu_program_parameters GL_EXT_gpu_shader4 GL_EXT_histogram GL_EXT_multi_draw_arrays GL_EXT_packed_depth_stencil GL_EXT_packed_float GL_EXT_packed_pixels GL_EXT_pixel_buffer_object GL_EXT_point_parameters GL_EXT_provoking_vertex GL_EXT_rescale_normal GL_EXT_secondary_color GL_EXT_separate_specular_color GL_EXT_shadow_funcs GL_EXT_stencil_wrap GL_EXT_subtexture GL_EXT_texgen_reflection GL_EXT_texture3D GL_EXT_texture_array GL_EXT_texture_buffer_object GL_EXT_texture_buffer_object_rgb32 GL_EXT_texture_compression_latc GL_EXT_texture_compression_rgtc GL_EXT_texture_compression_s3tc GL_EXT_texture_cube_map GL_EXT_texture_edge_clamp GL_EXT_texture_env_add GL_EXT_texture_env_combine GL_EXT_texture_env_dot3 GL_EXT_texture_filter_anisotropic GL_EXT_texture_integer GL_EXT_texture_lod GL_EXT_texture_lod_bias GL_EXT_texture_mirror_clamp GL_EXT_texture_object GL_EXT_texture_rectangle GL_EXT_texture_sRGB GL_EXT_texture_shared_exponent GL_EXT_texture_snorm GL_EXT_texture_swizzle GL_EXT_timer_query GL_EXT_transform_feedback GL_EXT_vertex_array GL_EXT_vertex_array_bgra GL_IBM_texture_mirrored_repeat GL_KTX_buffer_region GL_NV_blend_square GL_NV_conditional_render GL_NV_copy_depth_to_color GL_NV_explicit_multisample GL_NV_float_buffer GL_NV_half_float GL_NV_primitive_restart GL_NV_texgen_reflection GL_SGIS_generate_mipmap GL_SGIS_texture_edge_clamp GL_SGIS_texture_lod GL_SUN_multi_draw_arrays GL_WIN_swap_hint WGL_EXT_swap_control
wgl: extensions=WGL_ARB_extensions_string WGL_ARB_pixel_format WGL_ATI_pixel_format_float WGL_ARB_pixel_format_float WGL_ARB_multisample WGL_EXT_swap_control WGL_ARB_pbuffer WGL_ARB_render_texture WGL_ARB_make_current_read WGL_EXT_extensions_string WGL_ARB_buffer_region WGL_EXT_framebuffer_sRGB WGL_ATI_render_texture_rectangle WGL_EXT_pixel_format_packed_float WGL_I3D_genlock WGL_NV_swap_group WGL_ARB_create_context WGL_AMD_gpu_association WGL_AMDX_gpu_association WGL_ARB_create_context_profile WGL_NV_float_buffer
gl: extensions=(lockarrays) (multitexture) (pointparameter) (vertexbufferobject) (separate color) (anisotropic filter of 16.00) (compressed texture) (cubemaps)
wgl: extensions=(wglpixelformat) (wglrendertexture) (swapcontrol)
gl: reducing max texture size from 8192 to 2048
tmsystem: fullscreen modes=(640x480x16x59) (rj-640x480x16x73) (rj-640x480x16x75) (rj-640x480x32x73) (rj-640x480x32x75) (rj-720x480x16x60) (rj-720x480x16x60) (rj-720x480x16x60) (rj-720x480x32x60) (rj-720x480x32x60) (rj-720x480x32x60) (rj-720x576x16x60) (rj-720x576x16x60) (rj-720x576x16x60) (rj-720x576x32x60) (rj-720x576x32x60) (rj-720x576x32x60) (800x600x16x56) (rj-800x600x16x72) (rj-800x600x16x75) (rj-800x600x32x72) (rj-800x600x32x75) (rj-848x480x16x60) (rj-848x480x16x60) (rj-848x480x16x60) (rj-848x480x32x60) (rj-848x480x32x60) (rj-848x480x32x60) (1024x768x16x60) (rj-1024x768x16x70) (rj-1024x768x16x75) (rj-1024x768x32x70) (rj-1024x768x32x75) (rj-1152x648x16x60) (rj-1152x648x16x60) (rj-1152x648x16x60) (rj-1152x648x32x60) (rj-1152x648x32x60) (rj-1152x648x32x60) (1152x864x16x60) (rj-1152x864x16x75) (rj-1152x864x32x75) (1280x720x16x60) (1280x768x16x60) (1280x800x16x60) (1280x960x16x60) (1280x1024x16x60) (rj-1280x1024x16x75) (rj-1280x1024x32x75) (1360x768x16x60) (rj-1360x1024x16x60) (rj-1360x1024x16x60) (rj-1360x1024x16x60) (rj-1360x1024x32x60) (rj-1360x1024x32x60) (rj-1360x1024x32x60) (1400x1050x16x60) (1440x900x16x60) (1680x1050x16x60)
directinput: searching joysticks=none
tminput: searching for input devices...(1)
tmsystem: searching usb interface (0) 0=radiointerface
tmsystem: searching usb interface (1) 1=unable to open interface device
tmsystem: searching usb interface (0) 1=unable to open joystick device
tminput: 1 devices found
tminput: searching for input devices...(2)
tmsystem: searching dummy usb interface (0) 1=unable to open interface device
tmsystem: searching dummy usb interface (0) 1=unable to open joystick device
tminput: checking for joystick 0=fail
tmgl: loading font v2 texture/arial20b.tmf=(256x256) (32x255) ok
sim: loading scenery scenery/winzeln.geo...
sim: 1 objects 0 dynobjects
sim: start position 1 (not for helicopter)
sim: start position 2 (not for helicopter)
sim: start position 3 (not for helicopter)
sim: start position 4 (not for airplanes)
sim: load texture grid 5x5 (compress=1) named winzeln/winzeln=(5x5) (24x13) (72.00 36.00) (3.00 3.00)
sim: sphere params=-1.5000 0.0000 -0.7000
sim: loading ground object scenery/winzeln/winzeln.obj=ok
sim: loading time=58326 mus
tmcollision: 1604 triangles using 109072 bytes
tmcollision: omin=(-5000.0,-5000.0,-2.1) omax=(5000.0,5000.0,59.6)
tmcollision: octmin=(400.0,400.0,400.0)
tmcollision: otnodes=37 otdepth=11
tmcollision: otnmaxareas=838 otnavgareas=48 otnminsize=(312.500,312.500,61.746)
tmcollision: otareas=1801 mem=100856
tmcollision: otclppl=5604 mem=179328
tmcollision: 37 octrees, using 9620 bytes
tmcollision: total mem=398876 bytes
tmcollision: time=17933mus
tmcolldynamic: no dynamic objects or triangles
sim: loading aircraft 1 da42...
tmdairfoil: loading naca64a208 ok
tmdairfoil: loading naca0015 ok
tmdairfoil: loading naca0009 ok
directsound: register sound sound/aztec.wav=ok
directsound: register sound sound/aztec2.wav=ok
directsound: register sound sound/aztec2.wav=(already registered)ok
directsound: register sound sound/aztec.wav=(already registered)ok
generating shadow da42shadow0=radius=4.44 bbmin=(-2.22 -2.22 -0.38) bbmax=(2.22 2.22 0.42)
sim: creating blurr=LeftPropeller
sim: creating blurr=RightPropeller
loading input device calibration config/radio0.tmc=ok
tmmusic: off
tmsystem: calibrating radio deviations= 0 3 6 9 -16 25 (timer=22200) -36 (enhancing table=0->4) 88
tmsystem: aserial=18A9B896
directsound: loading sound 1 sound/beep.wav=(in software) cpu=0
directsound: loading sound 2 sound/balloon.wav=(in software) cpu=0
directsound: loading sound 3 sound/crash.wav=(in software) cpu=0
directsound: loading sound 4 sound/splash.wav=(in software) cpu=0
directsound: loading sound 5 sound/glider.wav=(in software) cpu=0
directsound: loading sound 6 sound/glider2.wav=(in software) cpu=0
directsound: loading sound 7 sound/aztec.wav=(in software) cpu=0
directsound: loading sound 8 sound/aztec2.wav=(in software) cpu=0
directsound: loading sound 9 sound/aztec2.wav=(in software) cpu=0
directsound: loading sound 10 sound/aztec.wav=(in software) cpu=0
directsound: loading sound 11 sound/aztec2.wav=(in software) cpu=0
directsound: loading sound 12 sound/aztec2.wav=(in software) cpu=0
sim: switching to simulation mode...
tmdynamics: simulation started
sim: building rflmaps=(0.00 0.00 0.00) done
sim: aircraft=(-8.00,7.50,0.37), viewer=(0.00,0.00,1.65)
sim: building rflmaps=(-8.00 7.50 0.37) done
sim: 645 memory blocks using 47322783 bytes
saving configfile config/main.mcf=ok
saving player configfile config/player1.mcf=ok
tmdynamics: simulation stopped
sim: load texture grid 5x5 (compress=0) named winzeln/winzeln=(5x5) (24x13) (72.00 36.00) (3.00 3.00)
sim: loading time=2524042 mus
tmcollision: time=18607mus
directsound: shutdown
init window=(window=1680x1050) (screen=1680x1050) (32bpp) (60Hz) (fullscreen)
init pixelformat=ok
sim: building rflmaps=(-5.86 8.90 0.36) done
tmmusic: off
init pixelformat=ok
tmmusic: off
init pixelformat=ok
