RCU Forums - View Single Post - need help for t7c
Old 07-29-2010 | 12:08 PM
Bax
Default RE: need help for t7c
If you are asking about a mix that would give the operation of the elevators and ailerons on the same control surfaces, similar to how you would set up an airplane with a delta wing, then you would want to use the built-in elevon mixer. It's use is detailed in the instruciton manual.
