need help for t7c
<span class="Apple-style-span" style="font-family: verdana, geneva, lucida, 'lucida grande', arial, helvetica, sans-serif; font-size: 13px; ">before all sorry for my english, i hope you will understand what i mean
<div>Hello,</div><div>I have a small concern of programming on my t7c is it possible to put the totalite of the running of the servo on the moitie of the command. with a delta mix. It is for the piloting of a paragliding RC.</div><div>Thank you
<span class="Apple-style-span" style="font-family: Arial, Verdana, sans-serif; font-size: 12px; ">in french!!!!!!:<span class="Apple-style-span" style="font-family: verdana, geneva, lucida, 'lucida grande', arial, helvetica, sans-serif; font-size: 13px; ">
salut a tous,
j'ai un petit souci de programmation sur ma t7c... est il possible de mettre la totalite de la course du servo sur la moitie de la commande. j'aimerai eviter les elastiques qui maintiennent le manche vers le haut.
c'est le pilotage d'un parapente RC.
merci</span></span></div></span>
salut a tous,
If you are asking about a mix that would give the operation of the elevators and ailerons on the same control surfaces, similar to how you would set up an airplane with a delta wing, then you would want to use the built-in elevon mixer. It's use is detailed in the instruciton manual.
