RE: the Invisible Mini
The only issue with the bigger power plants is ground handling and prop clearance.
I thought the saito 56 was perfect, but still a lot of torque. If you are adament on a 4 cycle, the Saito .56 is my recommendation.
I still think you'll be happy with a good modern .40 two stroke. If it isn't eventually enough for you, then I'd move up.
