RCU Forums - View Single Post - the Invisible Mini
Old 07-30-2010 | 09:30 PM
crash bandicoute
Default RE: the Invisible Mini
ORIGINAL: Gray Beard
Dang Brian, that really is a great looking Smith. I used up every piece of scrap covering in my shop for mine, looked like something out of a circus!! The reason I went to the OS .70FS was the .46 OS I had in it didn't fly the plane well enough for me. The other reason was I had the .70 on hand and it wasn't doing anything at that time. As for the ground handling with the bigger engine, I was in control of the throttle so there wasn't any great difference in how it wanted to get away from me. I'm sure Brian is correct though and the .56 may be a better choice?? I just didn't have anything smaller on hand. <span style="font-size: small">My Smith came out very tail heavy but it's been so long I can't remember how I set up all the gear. I did have two aileron servos though, it's just easier for me to set up two then one.</span> The two degrees of Diff just helps the roll rate. Try flying it once without it then try it with Diff and see what you like best. I find it helps with bipes and I test most of my planes to see if they work better with it or without it, only takes a minute to change it in the radio.
<span style="font-family: Comic Sans MS">when you built yours, you had the servos in the wings? how did you do this? were you using mini servos? i was wanting to do the same, but if i hold a standard servo, bottom to the rib or the drawing, the base of the servo is too think for the wing area.</span>
