ORIGINAL: ThumbSkull
Not publishing the weight is a good reason not to pick that airframe.
You want no more than 7lbs for that engine.
Before you learn to 3D, you need to learn that weight is everything.
You will not learn 3D if your plane doesn't have the right power to weight ratio.
You can get by with scale on 30% and up sized planes.
Ok, 7 Lbs = Airframe+Electronic+engine.
How much the electronic weight aproximately?
