RCU Forums - View Single Post - Hope for Scale Props for SPs
Old 08-02-2010 | 02:52 PM
andi3142001
Default RE: Hope for Scale Props for SPs
Received my 2-blade hub today, a spinner nut for the 120SP together with a pair of 19,9 inch and a pair of 17,9 inch SG blades. Quality is excellent, did not weigh yet but its low. The parts go together easily. I found that the crank is too long for the spinner nut (or the spinner nut too short), when the spinner nut is screwed fully in there are 10mm way to go to the prop. Contacted Mr. Ramoser, he offered to make a centering sleeve so I can get rid of the spinner nut (which is a heavy part) and use the original RCV screws for mounting the prop. As an alternative I think about removing the blunt end of the spinner nut so it can be screwed farther. There is no corrugation, neither on the rear nor on the front side of the blade hub, so I think I prefer the original lock nut.
regards
Andi
