Guys, I mounted the V2 with the supplied standoffs and it ended up with a 1/16 gap at the cowl and looks great. Drill the premarked holes and bolt it on. Every one asks me how I got such a good mounting and gap. I tell them with a lot of patience. Just bolt it on and go. If you would like some pics I will take them.
I'm sure we would all be very appreciative of some pictures of your engine install Skysafallin I know I defiantly would, could you please tell me the length of the standoff's your using? Did you have to open up the hole on the firewall to clear the carb? If so did the needle's clear the firewall? And the last question is did you have to alter the cowl mounting position's as supplied from the Pilot RC factory to accommodate the DLE 30V2 in any way?
Many thanks again!
