RE: nitro boat motor brake in
Full throttle on a slobbering rich setting isn't going to give you full speed or max RPM as it should be spitting out a lot of unburned fuel and oil. Running it in the water gives the engine a load that you won't get on a test stand or in the hull onshore.
