ORIGINAL: spitflier What is the gauge of the HD twisted Also I can't find any info on how to properly position the two antenneas in the fuse from the 9 channel should they be parallel to each other, 90 degrees or let them flop around just kidding I have looked in the paperwork for both the recievfer and xmitter and havent found and thing that mentions it
1. Heavy Duty Servo Wire = 22 Gauge .
Hitec Heavy Duty "Twisted" Servo Extensions
#54607S Male Twisted Servo Connector
#54608S Female Twisted Servo Connector
#54609S 6" Heavy Duty Twisted Aileron Extension
#54610S 12" Heavy Duty Twisted Aileron Extension
#54611S 24" Heavy Duty Twisted Aileron Extension
#54612S 36" Heavy Duty Twisted Aileron Extension
(#54804 50' Heavy Duty Servo Wire 22 Gauge
- is not twisted but easily separated and spun with hand drill )
Hitec Digital Servo FAQ
2.
Optima RX - Installation RX, BODA Antenna & Range Test..
" Install twin antenna of Optima 9 at 90* if possible, otherwise not as critical as some other brands."
Aurora A9, Spectra Pro & Optima - FAQ & Undocumented Features - Mixes, Setups, Tips. {Individual Links often updated}
Regards
Alan T.
Alan's Hobby, Model & RC FAQ Web Links
