RE: Loose High Speed Needle...RCV 1.20sp
Interesting, okay looks like the Teflon tape isn't the solution. Thanks.
Can you help me to understand your fuel tubing method? I don't understand where you are fitting the fuel tubing. Do you mean you slip a piece of fuel tubing slightly above the threads of the high speed needle, therefore the tubing acta as a bushing?
P.S. Can you suggest any protective measures I should take with the exhaust?
Raz
