RE: Loose High Speed Needle...RCV 1.20sp
The fuel tubing just slips over the needle and the tube the needle screws into
A pic is easier than words
If the muffler is the standard one with the pressed in end, then it WILL blow the end out.
I found the only effective way of keeping it together was a bead of weld around the end plug seam.
Same as the OS mufflers, they have the end welded on.
