RE: Loose High Speed Needle...RCV 1.20sp
Arruda,
Thanks for the reply. Yeah, my needle seems very loose. Enough to irritate the mixture setting it seems. It seems that a thicker 0 ring may do the trick aling with the fuel tubing solution that mboland mentioned.
RCV, are you going to chime in here? Would you mind sending me a set of O rings that would help tighten up my needle. That is of course, unless you can send me a better fitting high speed needle.
Raz
