RCU Forums - View Single Post - help! covering with koverall
Old 08-05-2010 | 02:15 PM
cloudancer03
My Feedback: (22)
Default help! covering with koverall
I got my plane all covered using koverall for the first time ..it actually looked good until I started tinkering with it.dumb! I sanded the fabric on the fuse thinking it would make the cover line blend in the fabric.well dont say it!!!I learned as usual the hard way you can sand too much so I have to re-do the leftover.no biggie except I ran out of nitrate and stix it.my question is can I apply the koverall over the frame and use some sanding sealer or better a bit of buytrate dope that I happen to have .the frame was originally done with stix and then I brushed over the frame with nitrate waited until it dried and tightened the fabric.given I did that can I apply the koverall to the area being done over and use the buytrate dope to seal the edges ..I know one can go over the other just forgot which way it works.. help.
