RE: ASP FS61 midrange problems
Sport_Pilot, thank you for the tips! I will try some other plugs and see if that changes anything. I don't fully understand the theory behind hot/cold plugs, but I guess it has something to do with the hot plug igniting the fuel too early, and that this is compensated by turning the needle valve out. With a slightly colder plug, I would be able to run slightly leaner?
