RE: On board Glow driver
You can use a round servo horn on your throttle servo and grind it like a camb lobe so the switch goes on from about 1/4 before idle. You also want an on off switch wired into the + wire that goes to the glow plug that is on the outside of the plane so the battery isn't always on when you turn off your plane.
