Basic Construction Question
You had indicated that you will be using balsa will a plywood doubler.
I would overlap the splice point so the splice of the balsa, and plywood are not at the same location. This will give you maximum bonding area. This in effect is laminating wood together which yields a stronger construction than a single piece of wood.
