RCU Forums - View Single Post - Converting an Alpha 40 to a 2 blade prop
Old 08-08-2010 | 07:56 PM
delman
Default RE: Converting an Alpha 40 to a 2 blade prop
You can knock the center out of the fly wheel weight and put it back on your engine. Try a 11x6 prop. You can use a 2 blade spinner or go get a dubro spinner nut instead. After putting every thing back together recheck your c.g. because of removing the weight up front.
