 Converting an Alpha 40 to a 2 blade prop >
Old 08-08-2010 | 06:38 PM
Default Converting an Alpha 40 to a 2 blade prop
I purchased an Alpha 40 trainer made by Hanger 9 which comes with an Evolution .45 TPS engine setup for a 3 blade prop. It has been a great trainer but I was thinking of converting it to support 2 blade props to get a little more speed out of it, but I do not know how.
From the Evolution web page I can find the prop recommendations but I could use some help on the steps required in order to mount them
Should I remove the weighted fly wheel and replace it with a prop driver?
Do I need a prop adapter or just a different spinner?
What kind of spinner?
Etc…?
Any help would be great
Thank you,
Steven
Old 08-08-2010 | 07:56 PM
Default RE: Converting an Alpha 40 to a 2 blade prop
You can knock the center out of the fly wheel weight and put it back on your engine. Try a 11x6 prop. You can use a 2 blade spinner or go get a dubro spinner nut instead. After putting every thing back together recheck your c.g. because of removing the weight up front.
Old 08-08-2010 | 08:00 PM
proptop's Avatar
My Feedback: (8)
Have a look here for some additional info...
http://www.rcuniverse.com/forum/m_98...tm.htm#9814983
Old 08-08-2010 | 11:22 PM
I left the flywheel weight on mine and put on an 11x6 prop. This woke it up quite a bit.
Old 08-09-2010 | 04:57 AM
I used a master airscrew 11x 5 - MA props are great for learning to fly as they don't break every time you have a prop strike. The 11x5 prop still gives some good braking for landing when it is brought to idle. I used a du bro 2 1/4 spinner.
Have fun.
Old 08-09-2010 | 08:59 AM
Indy Park Flyer's Avatar
I just removed the 3 blade Prop and installed a Master Air Screw 11x5. Works great and increases the speed and performance. I know some people don't like the fly wheel weight, but I have never removed it and the plane flew great until I had a servo failure and it ended up in a tree. Don't worry my servos were at least 3 years old os I wouldn't expect you to have any problems with servos unless you plane is older.
Indy Park Flyer
Old 08-09-2010 | 06:04 PM
Thanks everyone, that helps alot and I appreciate the help. Hopefully I can handle the speed.
Take Care,
Steven
